Newspaper 7.5 problems
Hi Tagiv team
After updating latest version of Newspaper theme, I am having various issues
1. WordPress dashboard has become super slow. even publishing a single article has become a great deal.
2. I can’t delete the theme from Admin-Panel. It gives message Migration failed: Theme file doesn’t exist. However, I can reactivate the same theme.
Can you please help in this regard?
Kind Regards
Azhar Nadeem
1. We do not have any reports of any slow down with our theme. We have lots of installs using the current version of the theme and we have no such reports from our users until now, so I think it;s safe to say that it is something on your end that is causing the issue. Please disable all plugins except visual composer, clear cache and reset cdn files. Then test again.
Also make sure you increase your system status parameters like so: https://forum.tagdiv.com/system-status-parameters-guide/
Let us know if you still have trouble with the admin panel
2. This is a wodpress issue that started from the latest update. WordPress will not allow you top delete any theme from the WP dashboard. You will have to use ftp. It’s a wordpress bug, not a theme bug.
