I have problem with Block setting in version 7.8
(last version 7.7 work fine)
When I add block in page i tried select article by TAG – and is not working. On page I don’t see any article.
Post ID filte – Work
Category filter – I have only 1 category (can’t test)
Filter by TAG slug – NOT WORKING
I tried to use:
name of tag: WAŻNE WIADOMOŚCI
1795
1795,
tag1795
tag1795,
… =post_tag&tag_ID=1795&post_ … (link from TAG in Browser)
Hello Robert Rodziewicz,
It is possible to be a problem happen due to your system status. Ensure that it is setup according to our documentation here -> https://forum.tagdiv.com/system-status-parameters-guide/ Use only the plugins that come bundled with the theme core files, remove all your additional customizations (custom code) and check the results.
Clear all your caches and check the results.
