Newspaper 8 and tagDiv Composer Update… for more than 5000 articles.
Hi !
I am using Visual COmposer for a long time and I would like to use the tagdiv Composer but…. I have more than 5000 articles.
How Can I do ? In my case, it is impossible to change articles manually.
When you decide to use tagDiv composer, all the pages will have to be recreated with the new editor. The tagDiv composer cannot be used on posts, only for pages. If you used Visual composer on posts, with specific Visual composer elements, these will not be displayed properly with the tagDiv editor
https://forum.tagdiv.com/visual-composer-tagdiv-composer-transition/
