Newspaper 8 – Problem with columns
Hi… after i tried make 3 columns ( | | | ) with Classic Mode OR Tagdiv composer the columns are done rows ( =_ )!!!
Help!
Hello kalabakos,
I have tried to add 3 columns on my side with TD-Composer and everything seems to work as expected, as you can see here -> https://www.screencast.com/t/4aw8j0csCY and the result is here -> https://www.screencast.com/t/lAtibrqoB
If the problem is not this, provide more details about this case, give me your website so I can check it and also, some useful screenshots so I will be able to provide a more accurate response.
Hello Catalin. Thanks for your answer… This happend when i tried 3 columns 1/4+1/2+1/4. If i tried 1/3+1/3+1/3 αs your example everything is ok.
Look my problem with images in 3 columns 1/4+1/2+1/4
https://ibb.co/myA02a
  • This reply was modified 9 years by kalabakos.
I don’t know how exactly are you splitting the row in that layout. There is no option to split the row like that in the row settings of tagDiv composer
– https://www.screencast.com/t/RkTQtBJHZ
– https://forum.tagdiv.com/tagdiv-composer-tutorial/
Maybe I am misunderstanding something.
