I have updated to newspaper 9.7. coming from 7.8 and I have a problem now. We have a lot of images in our posts. They all have the size 1000 x 500 (w x h). So far they were displayed without any cropping. No matter weather it was a mobile phone or a desktop computer. They all came out in a ratio of 2:1. Now they are cropped and I want to turn this off. Is that psossible?
For example see here:
https://www.blauwasser.de/erfahrungsbericht-vorausschauendes-echolot-garmin-panoptix
The images in the post are 696 x 400. This means the aspect ratio is 1.74 : 1 – but I want it to be 2:1
Thanks for your help.
Sönke
This can be achieve if you change the width of post or if you remove the sidebar.
In order to change the width of post, you need to use a single post template from tagDiv Cloud Library , you can chose from there a post template that have a large width or you can edit the template using tagDiv Composer.
You can check a similar topic for width -> https://forum.tagdiv.com/topic/icloud-template-margins-and-images/
