Newspaper and AdRotate Pro plugin problem
Hi there!
Recently we started a web (https://www.optimoda.es/) with Newspaper theme and for the managment of banners we install the AdRotate Pro plugin.
AdRotate Pro has the possibility of discriminating banners according to support (mobile phone or computer)
From the same banner I have two sizes, one for computer and another for mobile phone. For example, for a banner of 1068 x 275 pixels on the computer, for the mobile I have one of 300 x 500 pixels.
The problem occurs when the mobile phone does not show the full size of the banner. Only part of the banner appears. As if the container box did not adapt well.
In said container contains a shortcode referring to the group of banners.
I hope you can help me solve this problem!
Thanks in advance
The ads should be displayed how you create them. Which ones are you referring to exactly?
These are some of the ads at the moment on mobile
– https://www.screencast.com/t/osh22DSb
– https://www.screencast.com/t/0Z9ini1sjif
– https://www.screencast.com/t/h1ainkb8
– https://www.screencast.com/t/60xTsq8a
Hi!
This are the banners that not appear complete:
https://www.dropbox.com/s/5d4706m76t4rbgd/Screenshot_2018-09-12-09-21-15.jpeg?dl=0
https://www.dropbox.com/s/er0gtkvdg05apxc/Screenshot_2018-09-12-09-21-59.jpeg?dl=0
And the banners should be showed like this
https://www.dropbox.com/s/wp5v2f370z5lrz5/CREPUSCULO_300x500.gif?dl=0
https://www.dropbox.com/s/s1lmgj1huwhu7vy/Optimoda_banner_300x500.gif?dl=0
In the spaces there are also two more banners rotating, but in these cases it is clear that they are not complete.
I see them like this on a mobile phone at the moment, took a few screenshots
– https://www.screencast.com/t/VITF2DsLxo0
– https://www.screencast.com/t/KfNWwscOKaw
– https://www.screencast.com/t/6kHlQkyQZ7x
Seem alright to me.
Hello, I have already been able to solve the problem.
I have enlarged the size of the group of banners that contained the cut banners.
On the web the banners are 1068 x 275 pixels and in the mobile 300 x 500, then I have defined the group in 1068 x 500.
I solved it from the AdRotate Pro plugin. Not the theme.
thank you anyway!
