I have run into a weird issue when I installed wpDiscuz plugin for my client and his website. When I click any article on the home page, the rendered target page with the article has no clickable URL links at all. This issue was reported by people using the Microsoft Explorer and Opera browsers only. Firefox and Google Chrome work all right. When I uninstall the WpDiscuz plugin, the issue is gone. When the Newspaper theme is disabled, the glitch is gone and wpDiscuz works flawlessly even on MSIE or Opera. So, there must be some glitch in the Newspaper theme or some kind of incompatibility. Is there any way how to fix this issue?
Start MSIE or Opera and try it for yourselves: http://goo.gl/U43bYK
Unfortunately we have’t tested the theme using the WpDiscuz plugin so I can’t offer you an exact answer on this. I did accessed your site and also noticed that same behavior on chrome also.
Please let me know what theme version you sue and also make sure you disable all plugins also, leave just the VC plugin active, empty all caches, purge files if you sue CDN host, also disable all js/css/html compression and test again.
I’ll also add this on our todo list for further testing.
Let me now how it goes!
