Newspaper does not work anymore
Since this morning, without making any changes to our websites, the newspaper theme admin stopped working.
Theme panel is displayed but nothing works when you select menu items, such as ads. Only the import/export tab works. Also, td composer does not open, it spins, cannot edit pages.
Please help as we have important modifications to do and we cannot do anything.
Thanks!!
Theme cannot change site randomly, so something, like a plugin or whatever got updated on your site. Suggest checking error logs, try clearing cache, try clearing transients with wp-optimize, try resaving permalinks.
Then try disabling plugins to see if something you updated broke something else.
Theme cannot “suddenly” break for no reason. This is why disabling ‘auto updates’ is wise, and then keeping eye on when updates come up to ensure you stay secure; trade off on ease of use vs stuff breaking from being auto-updated.
Check all your plugins to see if activated properly, or anything disabled due to broken update, etc.
Not sure if that helps, but good starting point.
( I don’t work here. )
Same issue happening with me. I checked all of the above and nothing helps. I tried reinstalling Newspaper as well.
Hello AMW,
Please follow the FTP theme installation method because this is the surest theme method and check the results. Disable all of the untested plugins and see how it will work.
