Hello Everybody,
I am setting up the Newspaper theme on Siteground, however I have a few warning on the System update and although I have made the corresponding changes, the system status keeps showing a warning.
The settings for which I am getting the warning are:
1) mod_substitute. For this I have followed the corresponding guide and updated the .htaccess with:
<IfModule mod_substitute.c>
SubstituteMaxLineLength 10M
</IfModule>
However, the indicator on System status is still yellow.
2) Caching plugin – For this I am not using the proposed WP Super Cache, but rather SG Optimizer plugin from Siteground. Here I would be expecting the theme to be compatible with SiteGround’s plugin. Is this not the case?
For the SG Optimizer plugin I have both Dynamic Caching and Memcached enabled.
Any advice on how to resolve these two issues would be much appreciate as I don’t want to encounter any surprises afterwards.
Thanks,
Coinavalon
Hi Coinavalon,
Those are only warnings and from what you said above, you already made the necessary steps. Now those will no longer change in green, because for the cache plugin only if is used the WP Super Cache the status will be green (the check from the theme panel was made only for this cache plugin), also for the mod_substitute our theme only check if is not provide by host, is not checking if this is set in htaccess (if you set it like in our guide and you used the SiteGround indications -> https://elementor.com/help/siteground-hosting-compatibility/ then the problem should be solved).
So, since you already made the necessary changes for the system status, you should no longer about those
