Is there anyway I can move the article top ad to be above the post content? It seems to be positioned underneath the featured image on any setting. This is on style 1 – https://adcomm.co.za/how-public-relations-can-help-your-small-business-grow/
But… Even if I change my (site wide) post setting to style 13. It still displays the advert under the featured image. I would really like to have the advert show above the content. The same as in your preview please?
I have changed it to style 13 for post styles (global) maybe easier to see?
This topic was modified 8 years by
Adcomm_Media.
Adcomm_Media.
Hello Adcomm_Media,
If you want to make some changes to these post templates you should edit the post templates files from here -> https://www.screencast.com/t/yu9CLoCbp (single or loop-single templates).
Hi Catalin,
Please excuse my ignorance. I understand I asked about style 1. But let us for a moment please look at style 13. In the Theme Panel on style 13 the advert clearly shows above the post title. But yet in my post the ad block appears below the featured image, How come?
My apologies Catalin,
I see I was putting the Ad code in the wrong block in the Theme panel. BUT… Now I have a different issue that the same advert is showing up twice on the page. I have removed the Ad code from style 1. But it is still showing up in the same position?
Ok Never mind. I am an idiot 🙂 Thank you for your help!
I had the Ad code in the Article Top position still as well.
But another question sorry… Is there anyway I can make that Ad smaller perhaps? Is there a container somewhere perhaps?
Hello Adcomm_Media,
The size for Adsense can be changed from the theme panel, from here -> https://www.screencast.com/t/XT2MyTaOVYn and also, if you are using other ads, please check here -> https://forum.tagdiv.com/using-other-ads-non-adsense-ads/
Hi Catalin,
Thank you for your response.
Am I doing something wrong?
I use your code from the link – https://forum.tagdiv.com/using-other-ads-non-adsense-ads/ and the advert disappears?
http://www.screencast.com/t/SbkCQNo8chCO
http://www.screencast.com/t/J8q24UIiqBT
Also there is absolutely no mention of sizes in this link – https://forum.tagdiv.com/using-other-ads-non-adsense-ads/ or am I missing something perhaps?
Hello Adcomm_Media,
Here you will find only the classes which are available for each kind device -> https://www.screencast.com/t/2PMa9J4xf if you are using other ads. You should provide your website URL so I can take a closer look at it and also, so I can inspect your Ads section.
