Newspaper updated problem
Dear Sir
I have just updated the newspaper theme to the latest version, but after updating, I find my website seems to have TWO problems . Would you please give me a hand to check?
1: Website display Problem:After updated , my website display is the as same as before, for the previous version, you can find from updraft-plus backup
2; Can’t add new category into menu After updated ,  I can’t add new category into menu as before; detail can be found in following link: https://drive.google.com/file/d/1lJW18b4i67YQBIxZTV0-yANkCVLo5S1t/view?usp=sharing
I have also sent a email to contact@tagdiv.com for easy handle. Million thanks for your help
Please make sure that you do not have any conflict plugins, please deactivate ALL plugins except tagDiv plugins (theme plugins), also if you are using child theme or cache plugin, deactivate them, clear all cache and try again.
Also if you send us an email, we’ll check the problem and will try to fix it as soon as possible.
