Hi, just updated to latest version of new Newspaper 10
Now block areas are using full size images instead of thumbnails.
I have checked in theme panel and it is set to generate the thumbnails.
I have also tried regenerate thumbnail plugin..
But the problem seems to be the theme isn’t using the thumbnail image even though it is there.
Massively affecting SEO having the full size image used
Please make sure that you have activated the proper thumbs in order to show the featured images properly.
This can be found in here: https://www.screencast.com/t/N18dR3qZrh
After activating the thumbnail sizes you need to regenerate your thumbnails using a plugin. Check this: https://forum.tagdiv.com/using-the-theme-with-existing-content/
Please send an email at contact@tagdiv.com and provide wp-admin access, so we can investigate this issue. Also paste a link to this topic so we can easily identify you.
Let us know and we will gladly assist you.
