I just upadated Newspaper 9 theme to Newspaper X, beacuse like many other users, I was expectiong higher speed. But now I see that speed is not any better. I don’t know if I need to change any settings or I have other problems, that I don’t achive speed of your demo site (https://demo.tagdiv.com/newspaper_pro/) which is on Google PageSpeed Insights more than 90 on Mobile and Desktop. I allready have fallowed all you instructions to get more speed, this inclues installing WP Super Cache, changing setting of it and all other changes that you said I need to change for Newspaper 9. Please help.
Hello !
Your page seems to be affected the most by the lack of a cloudflare, images, external requests as you can see it here: https://gtmetrix.com/reports/stave.myprobet.com/X5ZGKPgq
Hello !
You can see those results by going into gtmetrix and test your website. Also please note that speed is not only directed by the theme. There are multiple factors like plugins, external links, host etc… which can affect your page speed.
Thank you for your understanding !
Hi, the problem is that after I updated Newspaper 9 to Newspaper X the website is slower. How is that possible???
You can check the images of speed before update:
– https://ibb.co/W3d6Xcf
– https://ibb.co/q7FX40n
You can check the images of speed after update:
– https://ibb.co/YBJgSPP
– Desktop is the same as it was before…
It seems that maybe is something wrong with the setting in WP, or some plugin like WP Super cache? You tell me? What can I change in the settings of WP?
Yes and I know that I dont have cloudflare, but still cannot be slower that it was before…
Hello !
– admin url and credentials
– cPanel url and credentials
Our team will take a look !
