Hi, is there a way to control the speed between each post listing on the newsticker? I think it goes a bit fast, is bthere a way to make it slower? Thanks.
The time bestrewn each post displyed in trending now block it’s set at 3000 ms. You can increase this time by changing this value from tagdiv_theme.js: http://screencast.com/t/r2nGILK8kZ
where do i change that? kind of a newbie here, thanks 🙂
You have to edit tagdiv_theme.js file and increase the indicated value: http://screencast.com/t/r2nGILK8kZ Currently it’s set at 3000 ms which means 3 seconds, so you just need to increase that value at 4000-5000 or any other value.
