How to make the next and previous articles links below the post appear based on the tags used for the post?
Unfortunately there is no option in the theme to filter these buttons and I cannot offer a quick solution for this. The code for the next and previous article below posts is located here: http://screencast.com/t/CNk6rR1p
You will need to alter this file in order to get the result you desire. It will require a bit of coding knowledge. You can hire a freelancer to do it for you if you want from sites like studio.envato.com as we cannot offer any custom work at the moment
