Next and Previous Posts
Is there any way to exclude a category so that it does not show articles from that excluded category on the single posts in the Next and Previous Posts section?
I’d really love to see this functionality added to the theme.
Many thanks,
  • This topic was modified 9 years by dmalhotra.
Hello dmalhotra,
Sorry, but the theme does not have any such an option that allows you to exclude or include such categories for this theme feature regarding on Next and Previous section, sorry! You should check the theme’s core files and implement it yourself through the code if you want to achieve as you wish. So, notice that is not a simple task and if you are not aware of the steps which are needed to take in this case, please consider hiring a freelancer/developer to help you because we cannot provide custom services at the moment, sorry!
HI,
Thanks for your prompt reply.
I wish that there was such an option for the Next and Previous Posts section. And Related Posts section. Many other free plugins allow this kind of basic functionality. Perhaps, this is something that could be implemented in one of the future releases?
Thanks,
Hello dmalhotra,
Sorry but please notice that we do not plan to implement or test these kinds of plugins in the future, sorry!
Hi Catalin,
I’m looking for the same. Could you please tell me which file the next and prev post settings contains?
Thanks in advance!
Hello loano1,
If you want to edit this section, notice that you should edit the td_module_single_base.php core file from here -> https://www.screencast.com/t/Cq7u3o8L39
