Next page for posts loop
The main page here: https://www.frikurir.se
has a posts loop with a header type 4 to start with. The maximum number of posts are 20.
Pagination is set to “Next Prev ajax”.
On my laptop/desktop this work fine and I can move between the different pages.
On my cell phone (I am not using a mobile theme) the page freezes instead.
See these screen shots:
https://imgur.com/a/7yYrmt8
https://imgur.com/a/IB62EnE
After 20 mins it still hasn’t finished and just sits there.
How to solve this problem?
All settings are the same regardless of screen size.
Hello !
Have you checked for a plugin conflict? You will have to first start looking for a plugin conflict. please deactivate ALL plugins except tagDiv ones, also if you are using child theme or cache plugin, deactivate them, clear all cache and try again.
Also you can try and remove and re-install the tagDiv Composer plugin and please send us a link to your website in order to take a look.
Let us know the results.
