Hi –
I have ‘next prev ajax’ pagination turned on, but it only returns the same results.
For example at the bottom of this page: https://nwlaborpress.org/workers-rights/
I believe there are hundreds of articles in that category, but it returns the same set.
Thanks,
Ben
Hello Ben!
Depending on the filter you’ve set and yes it is important to have more posts.
Try to set a limit, for example 4 to see if the problem of the next prev is still there.
Make a test and deactivate ALL plugins except tagDiv ones, also if you are using a cache plugin, deactivate it, clear all cache and try again.
Let me know the results!
