NextGEN Pro not working
In Newspaper 3.8.1 – gallery doesn’t display, and installing the NextGEN plugin also disrupts the formatting of the theme. Can you help? Thanks 🙂
Please give me your site url … where you have a gallery.
we have some information about the gallery here: https://forum.tagdiv.com/how-to-make-a-gallery/
Hi Radu,
It’s http://e8d.7b1.myftpupload.com. The NextGEN plugin works fine in posts, but not in the static page builder.
I tell a lie, it doesn’t work fine in posts any more either.
I see that now you use Jetpack gallery. Is ok now? Do you have a page with a NextGEN gallery to see the issue?
Hi Marius,
I tried the Jetpack gallery, but I have to resize all the photos manually every time to get them to look OK and ideally I’d like the formatting options, and the gallery organization possibilities (I have a lot of different galleries) from NextGEN Pro.
I want to use it on the homepage under ‘Browse Paris Events’. I’ve just added it now so you can see what is happening.
Thank you for your help!
I see that you have there some photo slides and work fine for me: http://screencast.com/t/Eb9UKGFbrqrV
Hi Marius,
Those are from the default image carousel, not NextGEN. They do work fine, but they are a bit heavy on page load…it’s not that big a deal but if there is a way to get NextGEN to work that would be amazing!
hi,
thanks for the suggestion, we will talk about this.
Thanks for you message.
Radu A.
