In order to duplicate the next and previous articles to have them display at the top also, you need to edit every loop file for the post styles that you use: http://screencast.com/t/LUOCBEi9ARO
Unfortunately we have not tested this option so It could not work properly when duplicated. You will have to run a few tests to see is it will work as expected.
