NFT Layout help
I am using the NFT Layout here: https://teqtoq.com/ensure-your-safety-with-stay-safe-the-revolutionary-fire-extinguisher-for-every-home/
Thing is, the sidebar when viewed on mobile comes up right after the share buttons, the sidebar should go all the way in the bottom when viewing mobile, how can we fix this?
thanks!
The sidebar is in the correct position when you check the website from a mobile phone.
Did you clear all the cache (also from your browser)?
Hi, yes i did clear all cache, the sidebar should come after all the content has finished no?
Please check the screenshot attached.
https://ibb.co/GTT4bbq
thanks!
A responsive version of your website looks similar to the desktop version. TagDiv Composer is used to edit the page. Click on the mobile viewport: https://www.screencast.com/t/XDQJedlggSB. There, you can see your mobile version and edit or adjust the elements to look better.
You can re-order the columns at any time on the mobile viewport: https://prnt.sc/GUZQ43nJiLEL
Please make sure this option is unchecked: https://prnt.sc/NajLBDrrtfTm
If i adjust the columns on mobile view, the desktop view is also affected, do you want me to send you the login to fix?
Yes, please. Contact us via email at contact@tagdiv.com and provide the following:
– admin url and credentials
thanks, email sent.
If you sent an email, then we will take a look and try to help you as soon as possible.
