No avatar users comment
hello
The theme use the default gravatar – https://codex.wordpress.org/Using_Gravatars You need to use a plugin like WP User Avatar We use it also on our demo.
I’m not sure if you use an avatar plugin, but we recommend this plugin.
Set avatar image – http://screencast.com/t/Jbqvmt9lp4
Result on comments: http://screencast.com/t/YWqMQAGSx
Can you show the place where the code is output to the picture commentator, thx
Here you can find the code for user avatar for comments – http://screencast.com/t/Qx3Qrkpi
