I’m using block 9 on this page: http://scotomastudio.com/commentaries-2/
Firstly, I don’t want the titles to get divided into two columns. I want it one after the other.
Secondly, is there a way to display post excerpt too?
Hello ipcs,
If you want to handle the title length for Block 9, you can do that from Theme panel, like this -> https://www.screencast.com/t/8Vjje3aKt
For your second request, please notice that the theme has not been designed to display the post excerpts for Block 9, sorry! If you want to do that, you should edit the theme core file which creates the Block 9 which is td_module_8.php like this -> https://www.screencast.com/t/tJTD1uU3UO If you want to display more levels in our theme and if you are not aware of the steps which are needed to take in this regard, please consider hiring a freelancer/developer to help you because we cannot provide custom work at the moment, sorry!
I tried what you mentioned but it didn’t work. I think you’ve misunderstood my query. Currently, Block 9 is showing titles in 2 columns. I don’t want that. I want all the titles to display one after the other.
Hello ipcs,
Unfortunately, this is the functionality of block 9 to be in 2 columns, sorry! We do not have any such a block with 1 column, sorry! If you want to display more details in our theme and if you are not aware of the steps in this regard, please consider hiring a freelancer/developer to help you because we cannot provide custom work at the moment, sorry!
I had the same question. The problem is that the icon for ‘Block 9’ indicates that you have the ideal layout of stacked list of posts in one column. I took the icon to be accurate since the ones that have image placeholders will by default, show images, and the ones that do not, don’t.
I was only saying that my request echoed ipcs’s. I also added that I selected ‘Block 9’, because the Block 9 icon implies that you can achieve a single list of post titles without thumbnails. The thumbnails part is accurate, but not the single column that would span a reasonable width of the page.
