No comment box on posts for Reel News Pro
Theme variant: Reel News Pro
I have enabled comments on posts and pages as far as I can see, but can only see comment boxes on Pages, not on Posts.
Homepage (you can see the comment box at the bottom): https://halftimelab.com/
Post example page (no comment box at the bottom): https://www.halftimelab.com/letting-go-pathway-to-freedom/
Comments seemingly enabled: https://imgur.com/a/R1JQly7
Any help would be appreciated, thanks!
  • This topic was modified 4 years by laquedu. Reason: forgot url
Hi laquedu,
This is because the pre-build website that you have installed is a PRO And use only cloud templates, so it will not use the theme panel settings, it will need to be used the tagDiv Composer, you need to edit the cloud templates and drag the elements you need -> https://i.imgur.com/KCCDk3z.png -> https://i.imgur.com/vC5tLj2.png
I hope this will help you!
