No Featured Images Settings under Post Settings and Changing Feature Images
awesome! Its sorted. 🙂
Another question – I wanted to know if there a way I can do something like 9gags like site with newspaper theme? basically post with image/video/gif ex like https://bimber.bringthepixel.com/gags/ see the mobile version of it as well.
Another issue. can I remove date/author from Mobile theme homepage? (I was about to remove it from the post using Theme Panel – > Mobile Theme – > Post Settings).
You can create modules, with featured images https://forum.tagdiv.com/modules-builder-newspaper-theme/
Do you use the mobile theme?
You can hide the author and date on that grid for the mobile theme plugin, from Theme Panel -> Block Settings -> Meta info on Modules/Blocks => https://www.screencast.com/t/CvxrWymeyk
1. I’ll look into creating blocks.
2. I tried https://www.screencast.com/t/CvxrWymeyk but it hasnt turned off the author and post date for Mobile theme homepage.
Please make sure that the settings are saved, and clear the cache.
I did but I think the redis on the server had cached. had to login to vps and flush it. It has finally updated.
Now I need to do the gag like theme. I’ll check what you posted above and see if I can do that.
Thanks again @anamaria
Hi there @anamaria I hope you are doing good. I’d like to say what template would you suggest for something like https://www.wedmegood.com ?
and inner pages like :
https://www.wedmegood.com/photos/wedding-decoration-ideas
https://www.wedmegood.com/profile/Pragnesh-Suthars-Photography-1147080
Yes, I am well, I hope you are well too.
I’m glad that the problem is resolved.
You can use the posts loop element for this type of design and set the modules https://i.imgur.com/DroxiLo.jpg or import those blocks https://cloud.tagdiv.com/#/single/page/Blocks/1497 You can import blocks or create your own modules https://forum.tagdiv.com/modules-builder-newspaper-theme/
Thank You @anamaria. With your help I’m learning my way with Newspaper theme.
Question I installed EastCoast Check PRO. How do I move the search to the center like wedmegood.com?
I pretty much tried doing all I can think of with settings but couldnt move it to center.
Which search do you want to align to center -> https://i.imgur.com/7R0jnKt.png ?
Hey @anamaria
This https://prnt.sc/lsp5FUcDj_hJ and I want to know if i can move it in the center and move it up and down the page with same background.
You need to change the layout of the row -> https://i.imgur.com/K5aphZJ.png or add a new row and add the element there.
@anamaria I wanted to know how optimized the newspaper theme is for woocommerce? Is there anywhere I can check it?
Please let me know what you want to optimize.
Actually I was looking some features like shoptimizer product page – https://shoptimizerdemo.commercegurus.com/product/endeavour-training-sports-top/
Change to mobile view in browser or use phone.
You would see that add to cart button is sticky
https://prnt.sc/qzZ7wlZzuBEq
when you click on add cart it shows selection options.
https://prnt.sc/s_5Sl9xWws-A
then when you click on Add to cart it shows Cart directly.
https://prnt.sc/9TiyQTo1YkhH
Is there a chance i can do that?
Unfortunately, the theme doesn’t have this option.
A workaround that can be done is to create a mobile template and set a row and do the row sticky bottom -> https://i.imgur.com/GKQiqBA.png
Hey @anamaria I hope you doing well. Is there a way I can convert my Newspaper theme header into elementor? I’m currently using https://demo.tagdiv.com/newspaper_style_pro/
Unfortunately, I don’t know how Elementor works.
I understand. I’m working a similar header in elementor. might not look same but works.
Another question @anamaria : how can I display number of comments in single post layout next to Author name and Date time.
Theme : https://demo.tagdiv.com/newspaper_style_pro/2019/12/12/td-post-how-to-become-a-fashion-influencer-from-your-own-home/
Also the changes I make like fonts / spaces and other stuff in the theme .. will they remain when I update the theme?
Thank You. 🙂
You need to add in the single post template the single post comments counter and check display inline https://i.imgur.com/SIYDWaz.png
Question 1 : I followed the instructions and I was able to add the comment counter. is there a way I can align it with the Author Name and Date? https://prnt.sc/b6oVQaDLgvAs
Question 2 : Another question: Also the changes I make like fonts / spaces and other stuff in the theme .. will they remain when I update the theme?
1. Please check the setting from tab css, and set margin-bottom here -> https://i.imgur.com/1XRhZlV.png
2. No, it should remain the same fonts and style you set after the update.
Also, you can use global font from Manager(Website Manager) -> Global fonts -> https://i.imgur.com/iY0bh4Y.png
Nice. I made the changes and I have upgraded the theme too. That Global font feature looks really nice I’ll try getting up the fonts once I get sometime. thank you.
Question : When I click on tagdiv CSS analyser I see a popup : https://prnt.sc/W9343kGp4t5e
but when I click on Generate Critical CSS. Nothing happens.
Please don’t use this tool because it is deprecated, and the featured update will be removed.
oh okay. then has tagdiv changed the way this is done or is it simply removed?
Viewing 25 posts - 26 through 50 (of 78 total)
