No Homepage Display Setting in Reading Settings
Hello
I am using Newspaper theme on my website. I am not able to find the homepage showing on my dashboard. It is not visible in “Reading settings” or in the customization section. I am attaching the screenshot too https://imgur.com/a/1AiJdBv
Please help.
Regards
Mani
The blog I need help with is: xrheadlines.com
Have you checked for a plugin conflict? Please deactivate ALL plugins except tagDiv ones; also, if you are using a child theme or cache plugin, deactivate them, clear all cache, and try again.
Yes, i have de activated all plugins and this is a new website. I re installed the wordpress and theme and it didn’t worked.
Please create a page, and check after or import it from tagDiv Cloud Library.
