After updating to the latest version, can no longer see the images on the homepage (sometimes) and in the sidebar modules. I tried your “fast solution” that you have proposed in another topic, but it does not work. Besides this there is a dysfunction in the TagDiv Composer plugin. When using the “row” function the page does not update and runs indefinitely.
I look forward to your reply
my website https://www.rightsreporter.org
Unfortunately it does, not always, but it does. I tried with Windows, with Linux, with all browsers and it does. Now I want to try to replace the plugin TagDiv composer with js-composer to see if it depends on that, otherwise I downgrade and go back to the previous version waiting for a new update that fixes the bug
Nothing changes with Js-composer. These are the desktop and mobile screenshots
http://i68.tinypic.com/6tmdtz.jpg
http://i64.tinypic.com/wgt2sh.jpg
This reply was modified 8 years by
rights reporter.
Please contact us at contact@tagdiv.com and provide wp-admin and ftp access so we can take a closer look. Also paste a link to this topic so we can identify you.
Please make a full backup before.
I just updated to 4.6 and my thumbnail images are no longer showing on the site. https://www.mads.asia/
I have now reverted back to 4.5 and the thumbnails are now showing again.
hello, excuse my english I use a translator.
I updated the template from 4.5 to 4.6 and the same happened to me
thumbnails disappeared, use a cache plugin in some browsers worked and in others not and when updating the browser was left without seeing the thumbnails, to correct the problem I had to return the template to the previous from 4.6 to 4.5. and everything was back in order, I will also wait better for there to be a solution.
Please download the theme package again and install it, there were some issues with thumbnails not loading in the initial package.
If there are still problems please send us an email at contact@tagdiv.com and provide admin login so we can investigate why this happens.
I did as you say, but the problem persists. The package has not changed. I’m sorry to have to change this theme after so many years, but if the problem is not REALLY resolved I’ll have to move on to something else
@rights reporter I have inspected your website, browsed it for a while. Where exactly are the problems with the thumbnails happening? I don’t see anything wrong with them
– http://prntscr.com/lhu8i0
– http://prntscr.com/lhu8pn
– http://prntscr.com/lhu8u4
We have investigated similar reports but found no actual issues. There was a problem with thumbnails in the menus after the initial 4.6 update. It was quickly fixed and the theme re-uploaded on themeforest.
