As per you documentation at https://forum.tagdiv.com/font-customization/ there should be a Google Fonts Settings option but I can’t seem to be able to find it. I need it since I want to enable Greek subset for google fonts. Version of newspaper theme is V 10.3
Thanks in advance.
George
If you are not using the standard pack you’ll see only this in theme fonts -> https://i.imgur.com/F1dzxYq.png but you’ll still be able to add custom fonts, but without standard pack you use cloud templates and the fonts will be set directly on theme using tagDiv Composer -> https://i.imgur.com/fuOsVwz.png
Thanks for your prompt response but since I’m a new user of your theme I don’t understand what you mean by “standard pack!” When I go to Newspaper->Plugins I see that something called “tagDiv Standard Pack” is Active. Is that what you mean or is there something else I should install/enable?
Thanks again.
Yes, that is the tagDiv Standard Pack, if that is enable -> https://i.imgur.com/nhWUlVc.png the theme fonts hould look like this -> https://i.imgur.com/xvtDuK1.png
The Google fonts Style should be in theme panel -> https://i.imgur.com/GXAZWPA.png please make sure that you have the tagDiv Composer activate -> https://i.imgur.com/hz9fdjD.png if there is still a problem, you can send us an email at contact@tagdiv.com and provide admin login, as well as cPanel. We will take a look. Include a link to this topic in the email.
Sorry, you were revering to these settings -> https://i.imgur.com/LYGCLf1.png these were remove from theme panel, because now the browses support these by default so is no need for the theme to load them.
