Not able anymore to switch menubuttons in Newspaper Theme panel …
Hi, maybe you could help me.
There is a problem since this morning with wordpress and newspaper theme.
I can´t see editor anymore while trying to create a new articel.
I can´t switch menubuttons in newspaper thema Panel anymore
I am not able to load up any photos.
Provider (Strato) told me there haven´t been any changes. What am I to do?!
Something must have happened that caused all those issues. A general step that you can try in this situation would be to deactivate all plugins except theme plugins, then check if this has any effect.
Also please check the theme system status and make modifications to the WordPress and server parameters mentioned in this guide, if it is necessary
https://forum.tagdiv.com/system-status-parameters-guide/
You could ask your hosting provider to check and make these for you, if needed. This might explain the theme panel issues and uploading problems.
Please let us know the results.
