Please provide more details about your issue, like the link to your website and screenshots/video.
https://www.screencast.com/t/Ohnlol5W
Whenever I click on the activate button after entering purchase code and email id the screen stuck here. Dont know why this happening im trying many times but the same issue occured.
Please make sure that you don’t have mixed content errors; you can check the console. You have to use an SSL plugin to fix it and then try to activate it again -> https://www.hostinger.com/tutorials/fix-mixed-content-wordpress/ -> https://wordpress.org/plugins/really-simple-ssl/
Also, if the theme can’t be activated, please check the console and see if there are message errors.
