Not able to change my title headings style on my custom widget smart sidebar.
I have an Archive section and the title doesn’t match the rest of my website.
Hello theoutj3,
Provide your website URL so also, some useful screenshots to display your issue and what exactly you want to change. Also, after you have made some changes in your website, clear all the caches and check again the results.
As you can see in this image, https://imgur.com/EIBAkvz , I have a section with blog posts, and on the side I have a smart sidebar. The part that says “Popular Blog Posts” has the type of Header that I want. I cannot find any setting that allows me to change the header for the Archives widget I have put into my smart side bar.
Hello theoutj3,
All the sidebar settings can be changed from Widgets section from here -> https://www.screencast.com/t/DTblkpmg1k You should identify your sidebar used by you and from this section change it from that section.
Thanks for replying again Catalin, but it seems like I have looked here before I even asked this question and I still cannot seem to change the font. As you can see here: https://imgur.com/PL0RQXZ and here: https://imgur.com/PL0RQXZ , even when I click “visibility” I can’t seem to find it.
Hello theoutj3,
What kind of WordPress version are you using? At my end does not appear that button for Visibility. I am using the 4.9.1 version of WP.
I am on the same version as you.
Hello theoutj3,
Send us an email at contact@tagdiv.com with your log-in information (wp-admin) so I will be able to investigate it closer your setup page. Provide there the link to this topic so we can quickly identify you.
