Not load images demo
I just installed the demo of newspaper and does not load images. http://www.alertaqro.com
  • This topic was modified 10 years by 123xneo.
Not all images from the demos on themeforest are included, as they are licensed images. The demo setups are to help build your own content, not provide content you use for real.
If that was not the issue, pardon my input.
Hello 123xneo
This problem is caused by a plugin that interferes with our theme’s lazy load animation. http://screencast.com/t/mykoiRlA.
You have this error in your console: http://screencast.com/t/MtTJlAuIFIA
You can either try to disable lazyload or try to disable all your plugins except visual composer and see which one causes the issue.
