not possible to move a block
there in the visual editor, I am trying to move a place block, but I can not because it appears a long, endless space beneath the block. how do I solve this problem? See example: https://uploaddeimagens.com.br/imagens/pular-png
I also checked this and did not found any issues moving the blocks from the pagebuilder. I’m not sure why you have this issue, I see that you have there Block 4 in a Tab, so please make sure that you move only the Block 4(I thisnk that you want to move only Block 4) – http://screencast.com/t/u8Hgje3Uk Please check this without any plugins active, leave just Visual Composer active and clear cache.
Hello! after the version of the newspaper has been updated to version 6, the problem of moving the blocks is resolved.
