Not seeing Read More in blogs
Here’s my website almost ready for launch. website
For some reason my blog posts are not showing “Read more” after the first few words. Can you tell me where the setting is to enable ‘read more”. Or is there something else I need to do when writing a post with Visual composer to insert that read more.
Also where would the settings be to set up how much text shows before the “read more” shows up.
I realize this is a VERY basic question. But I am stumped. (While I’m at it, how to I set the site to use www instead of just plusrowby.com Thanks!)))
Best
Rowby
  • This topic was modified 10 years by rowby.
Not all theme’s modules display Read More button so in order to have it on page you’ll have to use a module which have this button in its structure. For example you can use module 11 or block 12: http://screencast.com/t/5mhgRrGvZZsD – http://screencast.com/t/P0hXpFOS6bbG
The excerpt’s length can be set from theme panel > excerpts for each module: http://screencast.com/t/coHOqbW3
The theme don’t control site’s url structure and can’t force the browser to display www.
Thanks Andrei!
That “fixed” it. I’m seeing how TagDiv has a really powerful system! (And great support)
Rowby
