This is my website, in this website i am getting ‘Two’ Big Slides in Home page, and also not showing meta-info, and it is having lot of spaces between posts. for Block-2.
Could you please send me suggestions,
Thank You.
When you choose the page template with slider, you don’t need to also add another slider. So, you might change the page template for blank, and then you’d only have the one slider as you’d defined it 🙂
What META info are you missing?
To create meta data for the home page, you need to enter that on the “page” used for the home page. Highly recommended is the YOAST SEO plugin which lets you set the description, and all other meta data for your home page and also show preview of the SERPS snippet 🙂
Hope that helped. Been there 🙂
Thanks for the Reply.. but
http://i.imgur.com/cMFfBwg.png
In above link I’ve mention the Yellow Line. that ‘Date’ and ‘Number of Views’ are not showing in my site, and also,
http://i.imgur.com/MpuewhJ.png
in this link mentioned, it is having so much spaces in between Posts.
Thanks Christopher!
@thebharatnews
To show the meta date you need to enable it from theme panel > post settings like this: http://screencast.com/t/zweLxnoJf
For the spaces between posts please sue this custom css and add it in theme panel > custom css filed: http://screencast.com/t/ymdyzAMK1n6
As Christopher wrote, the first slider is added when you use the “homepage bg” template: http://screencast.com/t/msHYEZk2XxyL
And the second it’s the one you added using page builder.
To fix this you have to change the template or remove the one you added.
Hi.
http://i.imgur.com/E3iN4NW.jpg
My website in Small monitors looking like above link.
Slider is not looking properly in 1024 x 768 Resolution.
it is showing only one image..
and How can i put Favicon in my site.
Thank you
Thanks for quick reply..
But, Slider is not looking properly in 1024 x 768 Resolution…
I mentioned in above Link…
Hi..
I have one more problem..
in Reviews I am not getting stars in Home Page..
What can i do for show the stars in home page articles..
Thanks for Advanced…
Please provide more details about the issue you have with the big-slider, I have checked your site and tried to replicate it tested on different browsers and couldn’t see it. Please specify on which browser this happens.
For the reviews please make sure you set it like this from post editing panel: http://screencast.com/t/piJLhDp4iA and it will automatically show up on page like this: http://screencast.com/t/PViEFGD5k
read : https://forum.tagdiv.com/newspaper-documentation/ before you ask.. may be that documentation can help you…
