Not work tagDiv Mobile Theme
Warning: require_once(/Newspaper/includes/wp_booster/td_api.php): failed to open stream: No such file or directory in /home/xxxxx/fashion-diplomacy.com/www/wp-content/plugins/td-multi-purpose/styles/tds_api.php on line 9
Fatal error: require_once(): Failed opening required ‘/Newspaper/includes/wp_booster/td_api.php’ (include_path=’.:/usr/local/pear/php56′) in /home/xxxxxx/fashion-diplomacy.com/www/wp-content/plugins/td-multi-purpose/styles/tds_api.php on line 9
Hey.
After the update, the mobile version does not work.
Tell me what to do
  • This reply was modified 8 years by zatyshnyy.
Help
There is a problem with the mobile theme functionality after the latest theme update. We will provide a general fix as soon as possible.
In the meantime please edit the tds_api.php file found in the plugins directory->td-multi-purpose->styles, replace all the existing code with this one
– https://pastebin.com/megB4nck
Save the file and check the results, the mobile theme should work properly. Sorry for this inconvenience.
