You should fully delete the pirate version your friend apparently had — I may be mistaken, but best to be safe; and do clean install of WordPress to be safe. Do it via FTP, so you can delete old versions of theme folders (all of them!), old plugins (all of them!), and do clean full install of WP. Seriously.
@neotrope Reinstalling wordpress??? That is a long process. But will the pirate stuff harm my site in any way or the other??? @nairolf2013
hadharm.
Well, if there is malware, back doors, porn spam, etc. in the pirate version … uh, yeah, it probably will hurt your site — having no idea “where” the “friend’s copy” came from ?
You do realize this is the same as installing pirate software on your PC, there are many files, php codes, snippets, javascript — all of which can be damaging to your site if malicious.
Have you scanned your site with SECURI yet ?
Reinstalling WordPress is pretty quick if you know how to FTP stuff — unzip the clean WP installer from WordPress.org ( not from ‘a friend’ ) and then drag over all the pieces to your site “over-writing” the existing files … just to do quick safety check vs doing nothing at all. Replacing the default twenty-sixteen theme with clean version, deleting ALL other plugins and themes, is a wise choice.
Have you done anything at all, like research this on Google — it’s your site, only you can fix it if something is broken from using “borrowed” software. Theme devs can’t fix that for you.
http://www.wpbeginner.com/plugins/how-to-scan-your-wordpress-site-for-potentially-malicious-code/
Hopefully lesson learned!
We always recommend getting rid of pirated versions and installing the official version of the theme. We have never seen that logo before. It does not come from our theme.
https://null24.net/ is a well known pirate that is providing illegal/pirated copies of most themeforest themes.
SO yes…you are dealing with a pirated version that could harm your site in all matter of ways. The most obvious one being security threats that could have been injected into the code in these versions.
