Number of custom ads inside of Newspaper Theme Panel settings
I would like to increase the number of Newspaper Theme Panel settings custom ads placeholders. I need to publish more than 5 custom ads, and have them available inside of the tagdiv composer for easier management.
Please advise, what is the best way to do so.
If you need this in theme panel you will have to contact our custom work team here: https://tagdiv.com/web-development-services/ Unfortunately this is not covered by the support policy.
If you’re using PRO Demos or cloud library templates you are able the add the ads directly into the template as you can see here: https://www.youtube.com/watch?v=fa7GenCHcBU
