Hi guys,
Is it possible to number the posts in a block?
I’m using a Flex Block 1 block to display ten posts, and I’d like to number them so that they are numbered in the style of Smart List 5 (number in the top-left corner of the image). Can this be done?
Many thanks,
stuart
Unfortunately, the theme does not have any such an option for this functionality, sorry! If you want to achieve this, you need to customize it yourself through the code and if you are not aware of the steps which are needed to take in this case, please consider hiring a freelancer/developer to help you because we cannot provide custom work at the moment, sorry!
Hi Catalin. That’s fine, was just hoping you knew of a quick way to add some custom CSS to achieve it without having to go to a developer.
Many thanks,
stuart
