Numerous Theme Panel options won't load – potential lazy load error?
A large number of submenus on the theme panel are refusing to load, simply rotating the lazy load symbol for eternity.
Newspaper Theme Panel options won't load
This only appears to be happening on:
Theme Panel > Ads > All submenus bar ‘Background click Ad’
Theme Panel > Theme Colors > All submenus bar Header>Header, Footer>Footer, Footer>Sub-Footer
Theme Panel > Theme Fonts > All ‘Font Settings’ Submenus
Theme Panel > Translations > Translations
Theme Panel > CPT & Taxonomy > All submenus
All other Theme Panel menus and submenus appear to be working correctly.
To try and resolve the issue I have already unsuccessfully tried:
– individually deactivating all Plugins
– deactivating all the essential theme plugins and reactivated the theme
– Reinstalling WP
– Replacing Core Files
– Deactivating all Lazy Load settings (as per a previous thread on a similar problem)
None of these measures has had any effect on the problem as yet.
Furthermore, we are encountering the problem on all browsers we’ve tested (Firefox, Chrome, Opera, Safari), and on all Windows, Mac, Android and iPhone devices we’ve tested, as well as on different IP addresses from a number of locations throughout the country.
Both myself and our tech guy are completely stumped. We now need help! Pleeeasee!
Please check the system status parameters to be increased according to our documentation from here -> https://forum.tagdiv.com/system-status-parameters-guide/ Check the PHP memory parameter to be properly increased because this is most important. Maybe this parameter is exhausted and that’s why some of the functionality doesn’t work.
Many thanks for the reply, Catalin 🙂
However, these have all been substantially increased and it has not made any impact on the problem.
We are having the same issue. When we try to make changes on the theme panel (ie: fonts), it just spins and spins.
Hi all,
If you have respected all of the theme requirements and all of the system status parameters are correctly increased according to our documentation and if the problem persists, please send us an email at contact@tagdiv.com with your log-in information (wp-admin) and CPanel access so we can further investigate it closer your setup page.
Many thanks Catalin – have sent an email 🙂
Hi all, we had the same issue. Turns out it was the ezoic ad platform that was causing this. They made a fix and all is well on this.
Oh wow! We’ve just started with Ezoic, so this is almost certainly the issue! How did they fix it? Can you share the fix if poss please?
Not sure how they fixed it. But I let our rep. know, and their tech team went in and rolled out a fix for us.
Awesome – I will get on to our rep now! Many thanks 🙂
I also want to partner with Ezoic, is the Newspaper compatible with it?
Because the posts from 2016 say they didn’t test it. Is there anything causes a problem while using Ezoic?
Best
  • This reply was modified 6 years by tarik0980.
Please notice that we did not tested the Ezoic with our theme and therefore, we cannot say for sure if it will work or not as expected with the theme, sorry! Also, we cannot provide support for untested plugins.
