Offset category for "Single Related Posts"
Hi all,
is it possible to offset a category for the element “Single Related Posts”?
Thanks in advance,
Tim
Hello !
By editing your template with tagDiv Composer you will be able to set an offset over that element: https://www.screencast.com/t/nIyo72L39j3
Hi Vlad,
but is it possible to outclude one specific category?
Best regards,
Tim
Hello !
You can if you create another similar template only for the posts that will go in that category. And that template will not have the related articles.
Hi Vlad,
sorry for the misunderstanding. I would like to have one category of articles not to be a part of this “related articles”. So there should not be any articles of the particular category be shown in the “related articles”. Do you know what I mean?
Thanks in advance,
Tim
Hello !
If you’re talking about the Single Related posts that option is no longer available. You can now use the filtering options from any block as you can see here: https://prnt.sc/tywcqa
