Offset does not work in template
I set up category and tag template imported from Cloud Template. I added three rows with three loop module. Each loop starts from offset calculated from the former block, but it doesn’t work: I see the same posts in the three different loops. Here an example: https://www.studiarapido.it/tag/dante-alighieri/ https://www.studiarapido.it/riassunti/letteratura/
We do not recommend setting two posts loop on the same page/template, please use a flex block or another block, because most of the settings from the first loop element will be set for the second one.
You can use a flex block only on the category pages with its special filter: current category: https://forum.tagdiv.com/flex-block-settings-guide/
