Offset post not working
Site: https://capsulenz.com
Newspaper version: 11.1
Hi, I have a post loop set up on a category template with setting of 8. When editing template itself, it shows correctly, eg starting post in that section has title ‘Sample Post 8’ but on the live site it displays from post 1.
Screenshots:
Template: https://gyazo.com/46c95cfc06f89fa59934bfa082c37f5d
Live: https://gyazo.com/5b3844dcac2a6c2b87352aa9916f817c
Please advice how to fix this. Thanks
  • This topic was modified 5 years by redheaddigital. Reason: adding screenshot links
I would like to take a look and see what can be done there. Please contact us via email at contact@tagdiv.com and provide the following:
– admin url and credentials
Our team will take a look!
Sent thank you.
I am having this same issue. Can you please explain the fix?
Please note that you cannot set 2 postloops in the same page. If you want to have multiple blocks and use the offset that will work. But unfortunately it does not on the post loops.
