Offset posts in post loop not working
Hello
I have a category page using a cloud template and it uses 2 post loops inside and when I use the post offset feature the backend changes https://prnt.sc/MeYzRkycr9h0 and the display on the front end is not the same as the backend view https://prnt.sc/p7Bc0KBJyk3r .
Can you help me?
We do not recommend setting two posts loop on the same page/template, please use a flex block or another block, because most of the settings from the first loop element will be set for the second one.
Hello Anamaria
Ok Ana
Thanks for your advice 🙂
