Offset posts is not working in Post Loop
“Offset posts” is not working in “Post Loop”. “Offset posts” ignores the values set to it. As you can see from the screenshot, I set two “Post Loop” blocks in category page. In the first, the output of posts sets from 1 to 4, in the second one – from 4. But in fact, in both blocks the outputs are made from the first record. If I use Flex box, then everything works great. But at the same time, the size of the DOM structure increases from 1500 (post loop) to 10300 (flex box) and the page loads very slowly. All other plugins are deactivated. If Post Loop provides the Offset posts option, then it should work there. Or am I doing something wrong?
https://yadi.sk/i/umypt1DHrbiPOQ
https://yadi.sk/i/cdzDBTcDSl0Dzg
https://yadi.sk/i/h3-ofKhbkRsdzg
Hello !
Please note that unfortunately at the moment you can only have 1 post loop / page. Using more will not work on the live site.
Thank you for your understanding !
When do you plan to have offset posts working on tag pages?
Hello !
At the moment this is on our drawing board but at the moment there is no ETA For this. Our developers are working on preparing for the new Google implementations.
We are sorry for the delay !
