In my Category template, I have several Posts Loop modules and ad boxes set up like this:
Posts Loop (Limit to 4 posts)
Ad Box
Posts Loop (Limit to 4 posts, Offset = 4)
Ad Box
Posts Loop (Limit to 4 posts, Offset = 8)
Ad Box
Posts Loop (Limit to 4 posts, Offset = 12)…..etc.
However, when I save the Category template, I see the same four posts repeat even though the offset values are properly saved. Is this a known issue?
Hello !
From filters you can set so the posts will come from the current category as you can see here: https://prnt.sc/u9h7f2
When do you plan to have offset posts working on tag pages?
