Omit Homepage Post element from mobile
Hello! I would like to delete the Homepage Post element when viewing the website on a mobile device. Could you provide the code to do this? (The feature image zooms in and out when scrolling on mobile, and I have discussed this at length with your colleagues via email, and there isn’t a fix. So I would like to simply delete it from mobile viewing.) Thanks so much for your help!
Elements placed in the page structure cannot be removed just by viewing the page on mobile. I could give you a code to hide this element on mobile devices, it will look like this
– https://www.screencast.com/t/6P52VO9wWjk
This code has to be entered in Theme panel->Advanced CSS in the phones section
.home .td-post-header {
display: none;
Enter it there and check if it works as intended. Let me know if there is a problem.
