One problem:Edit with TD Composer
When I create a new page and Edit with TD Composer, the following error occurs:
Warning: file_get_contents(): SSL operation failed with code 1. OpenSSL Error messages: error:1416F086:SSL routines:tls_process_server_certificate:certificate verify failed in /opt/lampp/htdocs/wp-content/plugins/td-composer/legacy/common/wp_booster/td_remote_http.php on line 221
Warning: file_get_contents(): Failed to enable crypto in /opt/lampp/htdocs/wp-content/plugins/td-composer/legacy/common/wp_booster/td_remote_http.php on line 221
Warning: file_get_contents(https://www.dsez.org.cn/wp-content/plugins/td-composer/assets/fonts/font-awesome/font-awesome.css): failed to open stream: operation failed in /opt/lampp/htdocs/wp-content/plugins/td-composer/legacy/common/wp_booster/td_remote_http.php on line 221
Warning: file_get_contents(https://www.dsez.org.cn/wp-content/plugins/td-composer/assets/fonts/typicons/typicons.css): failed to open stream: operation failed in /opt/lampp/htdocs/wp-content/plugins/td-composer/legacy/common/wp_booster/td_remote_http.php on line 221
Hello !
Please make sure that you do not have a plugin conflict, please deactivate ALL plugins except tagDiv Composer, also if you are using child theme or cache plugin, deactivate them, clear all cache and try again.
When I active the plugin_tagDiv Mobile Theme, the following error occurs on page:
Warning: getimagesize(): SSL operation failed with code 1. OpenSSL Error messages: error:1416F086:SSL routines:tls_process_server_certificate:certificate verify failed in /opt/lampp/htdocs/wp-content/plugins/td-cloud-library/shortcodes/header/tdb_header_logo.php on line 611
Warning: getimagesize(): Failed to enable crypto in /opt/lampp/htdocs/wp-content/plugins/td-cloud-library/shortcodes/header/tdb_header_logo.php on line 611
Warning: getimagesize(https://www.dsez.org.cn/wp-content/uploads/2019/09/20190030a9bae8c5-6408-c14f-f90c-ce57c1779713.png): failed to open stream: operation failed in /opt/lampp/htdocs/wp-content/plugins/td-cloud-library/shortcodes/header/tdb_header_logo.php on line 611
that page used header template 29 -law firm.
I have disactived all plugins except tagDiv Composer.
Hello !
Please contact us via email at contact@tagdiv.com and provide admin login, as well as cPanel or FTP if possible. We will take a look. Include a link to this topic in the email.
ok
When I edit pages with td-composer, it has this An error:
Warning: file_get_contents(https://www.dsez.org.cn/wp-content/plugins/td-composer/assets/fonts/td-multipurpose/td-multipurpose.css): failed to open stream: operation failed in /opt/lampp/htdocs/wp-content/plugins/td-composer/legacy/common/wp_booster/td_remote_http.php on line 221
I have send an email to you!
I have sended an email at contact@tagdiv.com and provided admin login.
I have solved this issue,thanks。
How did you solve the issue?
Br
Adam
