One problem: I can not delete empty space from the header part
Accidentally, I entered an empty space in the header part (in the top main menu).I don’t know how I can remove empty sapce because I drag it to the bottom of the screen (where the delete bar comes out) but it does not appear to me with the empty space tool. Also, since I have an empty space in the header part, my home cannot be viewed either on my smarthpone or tablets.How can delete this empty space from the header part? And one question more: Do you think that when I will be deleted empty space from the headear (top main menu) my page will be able to display well on smartphones and tablets? Do you think that is the reason? Thank you very much.
Hello !
Please post a screenshot of your white space in order to inspect !
How can I sent it the image because here there is only image link tool but not attach image tool. Is it possible to contact to a general email adress?
Hello !
If you want to delete a row, you can delete a row with the empty column like using the right click on the row icon -> http://prntscr.com/owlyuw -> http://prntscr.com/owlynq or using the drag and drop -> http://prntscr.com/owlz2r
I don’t want to delete a row, I want to delete an empty space in the header of my website. But it doesn’t matter, maybe this is not the real reason why I can not see my website properly. The layout of my website can not be viewed correctly either in web format or in phone format. On this screen https://we.tl/t-BjISQALK5r you can see how I can see my page in tagdiv format (the design I’ve created and built with tagdiv).
On this other screen you can see how people see my website on website format, on mobile format and tablet format https://we.tl/t-L7Luney61T. Why do you think my website can’t be seen properly in any of the formats and it just looks correctly in tagdiv format?. Mywebsite is: http://www.minilittleparty.com Thank you very much.
Hello !
That aspect is the mobile theme being rendered on desktop.
Usually this issue comes from lack of a caching plugin. We do recommend using WP Super Cache as you can see here: https://tagdiv.com/wp-super-cache-plugin-install-and-configure/
I’ve tried to install the pluggin you told me (WP Super Cache) but I have some problems. I installed it but I can not configure it and it dosen’t appear in the bar settings. As you can see I have activated the pluggin https://we.tl/t-130qeQPJBB but the pluggin doesn’t appear in the settings box https://we.tl/t-bbV8TdrrO1 and when I try to press activate the pluggin this screen appears on my computer with the following text https://we.tl/t-vMXX4UoZX6 (Attention!
The /home/minilitt/minilittleparty.com/wp-content/advanced-cache.php file already exists. Delete it manually before using this plugin. If you still see this message after deleting it, please contact your accommodation support.)So, what can I do now? Do you have a private service that can fix all my problems because I’m wasting a lot of time and I don’t think I’m going to fix it.
Hello !
Please contact us via email at contact@tagdiv.com and provide admin login, as well as cPanel or FTP if possible. We will take a look. Include a link to this topic in the email.
