One problem i have..
i download a FULL WIDTH slider but i cant use FULLwidth, only in a box area…. this template dont support full width sliders?…
Thanks!…
if you look to my page http://www.padresybebe.com the slider on top must be full width on the page, but only is showing inside the box content not fully from side to side of the page, is there a way to make it work, or the template cant do that?
Thanks!!! 😀
On your homepage the big grid seams to be displayed fine, if this is what you mean. I didn’t found any slider on your page, please provide a link where you have this issue and a screenshot where I should look.
